I need a bottom radiator hose for 1940 commander I know it is 1 1/2 by 2" just can not find one. I have a flex hose I will try. any help will be great Thanks, Stan
1940 Commander Radiator Hose
Tags: None
If you have the old one, take it to a local FLAPS and see if you can check it against what they have in stock. You may well find one that will work, maybe with a little cutting. That's how I found one for my '50 Commander.Chip
'63 Cruiser
'57 Packard wagon
'61 Lark Regal 4 dr wagon
'50 Commander 4 dr sedan
I could not find a replacement lower radiator hose for my 41 Commander. Did not want to use a universal flex hose. After a lot of looking and comparing I found that a Gates 21810 hose can be carefully cut and fit to work as a lower radiator hose on a 41 Commander. This hose is listed as fitting 87-89 Ford F700 6.6L-L6 upper. Don't know how similar 41 is to 40 Hope you find this info useful. jww
