The speedometer wasn't moving as it should so we pulled it out and found that it was just gummed up with dirt and crud. Cleaned it out using electrical contact cleaner. Now it moves and acts like it should. I see a little well above where the cable connects.
Is this well and the odometer drive gears the only places that need lubrication?
What is the best lubrication to use in the well? I can't decide between 3in1 oil and the graphite speedometer cable lubricant.
How about on the odometer drive gears? A drop of oil or a dab of white lithium grease.
We also cleaned the cable and lubed it with the graphite cable lube.
