I have recently purchased a overdrive transmission for my 48 champion t96 what kind of trans fluid do i use and can i use a synthetic like royal purple
overdrive trans fluids
Studebaker also "allowed" the use of straight 40 or 50 weight MOTOR oil in overdrive transmissions. All too often, what happens is somebody pumps in hypoid lube, meant for differentials. The extreme-pressure additives in that lube can be hard on the synchros.
The overdrive does not need a heavy EP-rated oil. I have had good luck using motor oil, and they seem to shift better with motor oil than they do with staright mineral gear lube, ay least in my experience.
I can't see a downside to using synthetics, other than the seals used might not be up to the job of holding them, so you might experience leakage. You don't want to run dry in the overdrive!
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
Mark Hayden
'66 Commander
The original Borg Warner Overdrive manuals tell you the details on acceptable fluids (and everything else you could want to know about your overdrive unit). Download it free at Bob Johnstone's handy website, where he puts lots of Stude info at our fingertips:
[img=left]http://simps.us/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
The Red-Headed Amazon
Deep in the heart of Texas
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
Paul Simpson
"DilloCrafter"
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
Mark Hayden
'66 Commander
