Help taking Studebaker clock apart
You might take a look at the Technical Pages on this site:
He has a step by step of rebuilding 1956 and later clocks but it might help you as well.
I have both clocks kinda running. One ran for about 8 hours yesterday and seemed good and then stopped. It was not the contacts or the energizing the little wheel just stopped, like the spring did not have enough tension. The other runs well but will not energize properly. The contacts are clean but when they pop the winding part that spins open does not spin enough to open the points. I have read a few sites but none are exactly like this clock. What am I missing?51 Studebaker Starlight State Commander Coupe
53 Studebaker Starlight Regal Commander Coupe
62 Volvo PV544 Sport
I would have thought there would be screws on the rear of the housing, so the complete clock could be removed to clean and lube the gears.
I've used a toothpick to put a drop of ATF and the end of each shaft, and made clocks work again.
