Guys,
if i may ask what brand and size in (mm) spark plug wires are you using on a stock Studebaker 289 4bbl with a Delco points (window) distributor ? Also what is the OHMs resistance on them. Do you need a bigger mm wire when using a HEI distributor ? The wires on the car now are 6mm.....On some HEI cars I have owned certain spark plugs would continually foul because the resistance on that wire was too much and the spark was too weak. After checking and changing to a lower resistance wire it all but stopped. I know that the length of wire has a lot to do with it but some brands and sizes are better than others.
Stuhawk
Stuhawk
