1963 GT Hawk California Car 289 V8 Auto
--- -email is ospaul@toast.net
Great pics available---
I have 59 grille installed--but I HAVE ORIGINAL GRILLE and wheel well trim
289 V8 Edelbrock 4bbl , auto, E Spark---Otherwise stock
I have most of my Repair parts/receipt, Pwr Steeting, No A/C
Auto Trans rebuilt. Engine compression even all around.
The distributor is modified to an electronic Mopar ignition,
I installed new stainless steel exhaust.
The oil pan has been removed, to install new gasket,
and the rear main seal replaced.
Installed steel belted radials.
Front timing cover gaskets and crankshaft seal has been replaced.
Fuel Line replaced, done professionally.
New brakes & master cylinder.
Alternator re-wound/rebuilt by an electric motor shop.
Freeze Plugs replaced with brass freeze plugs.
New Motor mounts. New rear end pinion seal.
New fuel pump. Replaced (1) rear axle. Replaced Heater Core.
The accelerator linkage / Bell Crank was professionally reworked / Re-Fab'd
*****Needs steering box Rebuild ******
South San Francisco Bay Area
