Hi all, I was bringing small parts down from the mezzanine today, to clean and prep for assembly. The car has been painted once, and the trunk hinges were mostly covered in white paint, but when I went to clean them up with a wire brush, the paint came off fairly easy, and they look galvanized underneath. Does anybody know whether the hinges were body color, or were they galvanized on the finished car? I have the same question regarding the trunk latch. Thanks in advance for any info you might have.
Hawk trunk hinges factory color?
They were lightly cad plated, not galvanized although it looks similar. They mostly got left that way, some were over sprayed with body color... I soak mine in laq. thinner until the paint falls off and lightly wire brush them then 'spritz' with laq. clear to preserve the cad plate. Some just paint 'em.....
Is this true for 56 - 64 ?
Originally posted by (S) View PostThey were lightly cad plated, not galvanized although it looks similar. They mostly got left that way, some were over sprayed with body color... I soak mine in laq. thinner until the paint falls off and lightly wire brush them then 'spritz' with laq. clear to preserve the cad plate. Some just paint 'em.....Joseph R. Zeiger
Pretty much. I can't get to the '56, but the '63 here is just kind of one coat where the upper hinge meets the decklid and the rest is spotty, overspray, the lower hinge is the same.... One coat where it was an easy target for a lazy painter.....
