What is the procedure for removing the steering shaft from a 56 Hawk Ross steering box? It needs to be sectioned, for EPAS installation.
Steering Shaft Removal
You have to pull the box. Then remove the Pittman arm. Then remove the side cover. Then remove the sector shaft out the side where you just removed the cover. Then remove the 4 bolts on the top of the box, and the worm gear and shaft will lift up and out.Last edited by bezhawk; 02-01-2018, 07:13 AM.Bez Auto Alchemy
