View Full Version : Need a brake pedal assy for Auto trans 1957 Golden Hawk
(S)
01-19-2018, 01:56 AM
I need the whole works if you have it. I am converting a stick shift Hawk back to automatic and I need the brake pedal/ arm/ assembly for one, it does not have power brakes..... Thanks
345 DeSoto
01-19-2018, 09:18 AM
FWIW, I modified the Stock brake peddle/clutch peddle assembly on my Sky Hawk, then added an automatic peddle pad. It was not a difficult procedure...
brngarage
01-19-2018, 09:55 AM
Mike:
What are you doing with the removed stick shift parts? I may be interested.
Thanks Howard.
(S)
01-19-2018, 05:06 PM
69838Still trying to ID what may have been changed on the car, but I suspect during the 'conversion' the wrong one was used, or maybe the car had power brakes, but then they were changed. The car just does not stop like it should. Waiting on the build sheet..... Not sure what is happening with any spare parts, but its only a T 86 OD .
52 Ragtop
01-19-2018, 07:58 PM
Mike,
Check with Tom K in South Bend. He use to have "several" 55 gallon drums full if pedals.
Jim
brngarage
01-19-2018, 08:49 PM
Nothin' wrong with a T86. I still might be interested.
