Restoration of our '62 Daytona continues. Before putting the Daytona in the shop for mechanical work we removed all the exterior trim and chemically stripped the paint and shot the car with primer. In the stripping process we found the passenger door had considerable filler. When the filler was removed we found a tight(close together) series of vertical, shallow "ripples" in the passenger door skin. It looks like what you would see if you throw a small pebble into a pool of water. There is no sign of any other damage and the door lines up and opens and closes fine. I can't imagine how the door could have been damaged to create this effect and and wondering if it is a manufacturing flaw of some kind. This then caused me to wonder if the doors on the Daytona are interchangeable with the Lark 2 door hardtop? Given the different side trim on the Daytona and Lark, are the contours of the doors different as well. And how about the front fenders? Are they interchangeable with the Larks? Just wondering......
Are 1962 Daytona and Lark doors interchangeable? Ripples in the door skin?
Tags: None
A '62 Convertible and a Hardtop are BOTH Larks, they both came in Regal or Daytona Trim >meaning the Lark Daytona's had Bucket Seats Standard.
The difference in extra Body Side Mouldings are just holes, that's it. A 2 Door Hardtop in Regal or Daytona trim DOOR will work fine, it is the SAME.
But that Door should be more than fixable just do a Better job of taking out the wrinkles before a thin coat of filler than the last Guy, Macco or Earl Scheib, they are not being Made anymore you know!
A Lark Deluxe 2 Door SEDAN however, will NOT fit.Last edited by StudeRich; 01-08-2018, 12:34 PM.StudeRich
Any hard top or convertible door from 61 to 62 is interchangeable albeit the trim between 61 (follows the door handle) and 62 (follows the crease) is different. 62 trim should be the same except for the "Daytona" spear that goes under the trim on the door. The trim has cut outs for the spear and the spear is fasten with screws, then the trim goes on top, so don't damage your Daytona trim.
61:
62:
daytona:
I agree with Rich that a little bond is not a crime.. And keeps you from having to adjust the "new" door and adjust the vent window.
The vent window has three adjustment points. eeek!
Thanks Rich. I was pretty sure the doors were the same but thought it was worth checking. We do plan to use the door. Actually the Maaco guy did a pretty good job since there were no signs of the wrinkles until we stripped the door. I had an old timer (actually I am an old timer myself!!) say he thought it was fixed at the plant before it was shipped new. Still can't fathom how the wrinkles got there..... Thanks again Rich.
Originally posted by JKelly View PostRestoration of our '62 Daytona continues. Before putting the Daytona in the shop for mechanical work we removed all the exterior trim and chemically stripped the paint and shot the car with primer. In the stripping process we found the passenger door had considerable filler. When the filler was removed we found a tight(close together) series of vertical, shallow "ripples" in the passenger door skin. It looks like what you would see if you throw a small pebble into a pool of water. There is no sign of any other damage and the door lines up and opens and closes fine. I can't imagine how the door could have been damaged to create this effect and and wondering if it is a manufacturing flaw of some kind. This then caused me to wonder if the doors on the Daytona are interchangeable with the Lark 2 door hardtop? Given the different side trim on the Daytona and Lark, are the contours of the doors different as well. And how about the front fenders? Are they interchangeable with the Larks? Just wondering......Gary L.
Originally posted by JKelly View PostThanks for your response, the photos and the good advice. We will certainly use the door. As you suggested changing door would be a bear! I was not aware of the 3 adjustments for the vent window...eek is not strong enough!!
Top front one tilts it fwd and back,
Top inside door tilts it in and out,
The bottom one adjusts to follow the bottom angle after the two are set.
And only adjust the vent window after you get the door aligned.
It would be nice if an original factory worker could of provided insight on how to line up the doors and vent windows.
Doors
Windshields
For some reason, not all the windshields survived the adjustment.
Bob
- Likes 1
Originally posted by studegary View PostYou say "vertical, shallow 'ripples'" then you say "like you would see if you throw a small pebble into a pool of water". It can't be both. The pebble would make concentric circles and not parallel lines. If it is circles, I imagine some foreign material got in the die set when that door was pressed. It wasn't bad enough to discard so it was repaired. Factory repair of panels was not unheard of in the 1950s-1960s.
Originally posted by JKelly View PostRestoration continues on 62 Daytona. I found a solid 62 four door lark with good front fender, hood and truck lid. Will these part fit my 2 door Daytona?Gary L.
