Started working today on setting up my front brake conversion. If everything goes as planed it should take a drum brake car and turn it into a late model disc brake set up for about $300 in parts including the caliper bracket using easy available over the counter late model parts. Will keep all of us CASO's informed in how it goes and do a break down on what you need to do and how.
brakes
It's been done before. Stock Stude hub, no modification. Homemade 10mm thick waterjet cut steel brackets. grade 8 bolts and spacers to fit the spindle back side level. Off the shelf Jeep rotor over Ram truck shouldered lug studs. If one had the stock rotors, then all you would have to do is make the brackets and order the calipers for thinner non vented rotors.Bez Auto Alchemy
Benz. I got the 2000 Jeep rotors. They fit the hub just fine but will need longer studs. The stock jeep look like they will work but are going to need a slight ream on the hole size. Waiting on s-10 calipers and a bracket from speedway motors and will need to rework the bracket to fit as needed. Which looks like to only hard part of the whole deal. So should be real close to your system. Then just going to add a corvette double master and a adjustable valve to the rear. No power.
Originally posted by swvalcon View PostBenz. I got the 2000 Jeep rotors. They fit the hub just fine but will need longer studs. The stock jeep look like they will work but are going to need a slight ream on the hole size. Waiting on s-10 calipers and a bracket from speedway motors and will need to rework the bracket to fit as needed. Which looks like to only hard part of the whole deal. So should be real close to your system. Then just going to add a corvette double master and a adjustable valve to the rear. No power.
BTW, the name is Bez, no "N" like the Mercedes. Either that, or I have been spelling it wrong my whole life.Bez Auto Alchemy
Here's the hub and rotor. The hub is the stock Studebaker with the drum removed and the rotor is from a 2000 Jeep Cherokee front 4 wheel drive. The stock studs are just a tad short by the time you get the rotor and the wheel on and would by unsafe as they do not extend pass the nut by the 1/2" min. You should extend pass the nut by the diameter of the stud as a min.which would be 1/2". Hub fits the rotor just fine and fits in to the wheel as it should with room to spare. Rotor is 11" and cost me $32 at the local parts store. Lot better that $199. ea. Next is to mount hub to spindle and be sure everything clears and I don't think there will be any problems. Then it's simply fit the caliper and build the bracket to hold it where it needs to be as soon as they get here.
Originally posted by swvalcon View PostThen it's simply fit the caliper and build the bracket to hold it where it needs to be as soon as they get here.
Originally posted by bensherb View PostThat's where any problem that exists will arise. Everything will fit around a rotor easy. Don't forget to check your wheel fitment round the caliper too. That is where you'll probably run into problems if you want to run a stock type steel wheel.Bez Auto Alchemy
