View Full Version : GT Prep For Paint Job
JoeHall
12-23-2017, 02:04 PM
Next week's mission is to get the 63GT prepped and delivered to the paint & body shop by Friday. I have all parts needed to repair the rear end damage: trunk, rear shroud, etc.. But must remove all, "bright work" and a few extra pieces before taking it to the shop, since I am changing the body color from black to champagne gold. In addition to everything shiny, will remove the door panels, since he is going to remove the doors to paint the jams. Also will remove the fender vent doors, and front & rear corner pieces, so as to get paint everywhere it needs to go. Gonna leave the front gravel shield on, but will remove and disassemble the side grills.
Having disassembled and repainted the car only about four yeas ago, I anticipate everything will come off easily. But it is still gonna take 15-20 hours in the garage to get my part done. The paint & body guy said it will take him 3-4 weeks from the day I drop it off. So should have a fun February putting it all back together.
It is not gonna be concours level, but hopefully very presentable when done. Gonna leave the top white, and the trunk and engine bay black. Not worried about being, "correct" when it comes to details like that. Just gotta get up the gumption to get out into the garage and get started.
63 R2 Hawk
12-23-2017, 02:47 PM
Sounds like the right way to do it, now get out there and git 'er done!! When I painted my Hawk, I took all that stuff off and I also *carefully* drilled out the swages on the headlight surrounds and drilled and tapped the bosses 6-32 so I could disassemble and paint the die cast pieces without having to try and mask the chrome part. Reassembled with SS button head socket screws so the "next time" I paint the car I can take 'em apart easily. And don't forget to paint the metalwork behind the hood satin black, or you will be reminded on the forum.... ;)
harry
12-23-2017, 04:17 PM
Are you painting under the hood also?
63t-cab
12-23-2017, 05:41 PM
Joe, I think You have a sound plan in the works. the end results should be nothing short of what You're striving for, and look forward to lots of pics.
studegary
12-23-2017, 06:45 PM
Reread the initial post - he is leaving it black.
JoeHall
12-27-2017, 12:51 PM
Well I drove the car the 10 miles to the paint & body shop today. Left the head & tail lights on for the drive, in case I ran into LE along the way. With the wife's help, it took only a few minutes to remove them, once there. It is totally stripped down, so now the ball is in their court, and they estimate less than a month, "unless we get swamped with deer hits again". Last month, with hunting season and deer moving around more than usual, they were swamped with cars that had hit deer. Sounds like that is a perk they can count on annually, thanks to deer season.
They are doing a frame-off on a 65 Chevelle, sitting in a corner, and the detail of their work is impressive. The shop has three full time people, and each seems to have a specialty, in addition to general skills. One guy operates the, "puller" which they will use on my car, in the area where the trunk latch is located.
Looking forward to getting it back. If they do as well as I anticipate, they will probably get the 56J this spring or summer. Last painted in 1987, it is way overdue. Keeping my fingers crossed.
63t-cab
12-27-2017, 05:19 PM
Joe, it sounds like You have a pretty good grip on what the Shop is capable of doing with the Hawk. are You going base coat / clear coat ?
JoeHall
12-27-2017, 05:27 PM
Yep, BC/CC. This is the first car I ever tried BC/CC on, and did so last time around when it was painted black & white four years ago. That turned out disappointing, though I really have myself to blame more than anything. I decided to use a paint brand I have since forgotten the name of. It is supposedly real good stuff, but has major differences in how it is to be applied. The painter was not familiar with it, and there were problems. This shop owner said he only uses PPG, and would not even discuss anything else. So I said, PPG it is. Learned my lesson leas time. Gonna stick with what the painter knows best.
63t-cab
12-27-2017, 05:43 PM
PPG IS good.
TWChamp
12-27-2017, 06:30 PM
I sure wish my 50 Champion was painted with PPG enamel when it was restored in the early 90's.
The unknown brand lacquer looks like crap now.
wdills
12-27-2017, 07:42 PM
True PG is as good as it gets. They have their cheaper lines called Omni and Shop Line. As long as they are using actual PPG, you are good to go.
JoeHall
12-27-2017, 08:01 PM
Reading on-line, it looks like Deltron is their good stuff. Is that your understanding ?
Thanks
63t-cab
12-27-2017, 08:22 PM
Joe, if You haven't already done so You may want to discuss the Shop use a High Solids Clear.
JoeHall
12-27-2017, 08:28 PM
The guy is real proud of his clear. Promises I will love it, and guarantees for as long as I own the car. Not sure what it is, but it sounds good. Wish I knew a lot more about paint than I do.
63t-cab
12-27-2017, 08:41 PM
In that case He's referring to H.S., He would not even dare to use Mid Solid and give that guarantee !
wdills
12-29-2017, 02:27 PM
Yes Deltron is their good stuff.
JoeHall
01-02-2018, 10:22 AM
Just talked to the painter, and he said he plans to use, "DBC". He said that is PPG's newest technology, and it replaced Deltron. Is that accurate?
Thanks Much,
Joe H
01-02-2018, 03:00 PM
Could it be Deltron Base Clear? = DBC
wdills
01-02-2018, 03:21 PM
I used DBC basecoat on my car. The can has Deltron written down it in very large letters. They have several good clears but the DC series clears still have Deltron written on the label.
63t-cab
01-02-2018, 03:24 PM
Joe, DBC uses regular/standard Reducer. DBU uses a activated Reducer, and is likely more user friendly when and if another repair is needed. a few years ago the Shop i worked at was PPG and We favored DBC for the most part. the Shop in question sounds as though they'll do You RIGHT :!:
Thanks Much,
Joe H
