I just discovered a puddle of tranny fluid shortly after a lengthy engine rebuild. Why would the seal give way so quickly? Also rear seal leak, which seems to be endemic with our cars.
Big fluid leak
Tags: None
If engine is out always replace front seal on trans b4 reinstalling engine. Lots of folks bolt torque converter to engine; its easier on trans and seal if converter is slid onto trans before engine is dopped back in and then bolted up to flex plate. With my luck the new seal would be defective.
Originally posted by jackb View Posttranny fluid would have little or nothing related to engine rebuild, unless part of the servicing...
If the mechanic replaced the seal, he destroyed it when reinstalling the motor. If he did not replace the seal, he either forgot or assumed the 50+ year old, rock hard seal would be OK. Either way, he should make it right, free of charge. It spells gross incompetence/negligence, and he should be embarrassed.Last edited by JoeHall; 12-22-2017, 06:27 AM.
Originally posted by JoeHall View PostIf he did not replace the seal, he either forgot or assumed the 50+ year old, rock hard seal would be OK. Either way, he should make it right, free of charge. It spells gross incompetence/negligence, and he should be embarrassed.
Originally posted by mbstude View PostUnless, of course, the car owner complained about the cost of everything, and the shop only did exactly what was asked. I've seen that happen as well.
I could be wrong, but the OP seems like the kinda guy who woulda opted for option 'A'. Now, his only option is 'B'.
