View Full Version : 61 Hawk Radio
wdills
12-04-2017, 03:15 PM
When I built my car I installed a Retrosound radio. It fit nice but never looked right. The first year the car didn't see much use because I was constantly addressing some issue. This year I was finally able to enjoy the car and get it out quite a bit. My new Retrosound radio quit about mid year.
I have been thinking about having an original radio retrofitted with modern "innards" so it will look right and give me more than just AM reception. I dug out what I thought was the original radio and discovered it was actually a 59 radio according to the parts book. Therefore I have two requests:
Anyone know a vendor that has a bunch of radios where I could buy a correct core to have refurbished?
Could someone please post a photo of their 61 Hawk radio so I will know what it is supposed to look like so I can buy the right core?
12-04-2017, 03:25 PM
The Push button portion of the Faceplate, Mounting Plate and Hole in the Dash got DEEPER in '58 I think? I would think '58 to '61 Hawk Radios would work, but Bud is the expert here not me. :confused:
I do know that 1961 and or '62 was the First Semi-Transistor Stude. Radio, so that alone would roll the AC Part number. But just about every Year for Sedan, Lark, Hawk units the Number rolled.
The '63-'66 all share the same basic shape and are Fully Transistorized, no Tubes but a different FIT.
If you PM "Bud" here on the Forum he can help, he rebuilds these Radios.
UPDATE: I found his Profile for you with a Member Search:
http://forum.studebakerdriversclub.com/member.php?3995-Bud
Bud
12-04-2017, 03:47 PM
The 1959 and 1960 radios are interchangeable and so is the 1961 radio, but the dial face on the 61 radios are white while the 59 and 60 radios are black. You can use a 1958 radio if you can find one that doesn't have the push buttons completely destroyed. The manual tuning 1958 radios will work, but they are fully vacuum tube and are larger than than the later hybrid models. The radios are also the same for either the Hawks or Larks with a minor difference in the rear mounting bracket. I'll have to check my stock, but I should have a rebuilt manual tuning radio for a 1961. If you don't want to go to the expense of having the radio completely rebuilt with a modern printed circuit board installed, you can also use a RediRad converter which plugs in between the antenna lead and the radio allowing you to use an Ipod, XM radio or phone with your original radio and the cost is around 100 bucks. Bud
RadioRoy
12-04-2017, 04:49 PM
61 is the last year of the fat push buttons and the only year that the fat push buttons were black. 58-60 have fat white push buttons that rot away from the sun.
studegary
12-04-2017, 04:54 PM
1958 Studebakers and Packards had radios with transistorized power supplies (the Signal Seeker and the push button, not the manual tune [only in Studebakers]).
WilburV
12-04-2017, 06:08 PM
wdills, check your pm's. I'll soon have a '61 Hawk radio available.
