is there a number where studebaker stopped using the mercedes star logo after they were sued? i have an early starliner with the mercedes star identification; really curious as to where it fits into the picture. thank you.
early 1953 studebaker vin, (serial) numbers
Originally posted by arkusvt View Postis there a number where studebaker stopped using the mercedes star logo after they were sued?
Marksigpic
S2Deluxe = (5H - C3).
They continued to use the tristar as a raised section of the back-up light lenses on C/K cars until 55. That was aldo the last time they used glass for major lenses (except for license lights.Bez Auto Alchemy
Originally posted by S2Deluxe View PostOn the C/K bodies, at least, I believe, the Vernon assembly plant in southern California, used them throughout the entire 1953 model year.
MarkGary L.
i haven't purchased a body parts manual as yet. the vin.# is 8323568, the body# is 4H-K5,8802.the body plate is attached by two phillips head screws. is that correct? the car was repainted with a color change 28 years ago; the plate and screws are the new color. i acquired the car from an 84 year old gent who bought it 50 years ago from the original owner; it has 29k original miles on her, with only 9k added in the last 50 years, so i have no reason to question anything, just curious. thanks for any help!gfperry
Originally posted by arkusvt View Post...the body plate is attached by two phillips head screws. is that correct? the car was repainted with a color change 28 years ago; the plate and screws are the new color.Brad Johnson,
'56 Sky Hawk in process
Per the 53-58 Body Parts Catalog, Pg 30 [Closed Bodies, U S A]
Note #24
Type "A" emblem [tristar] used on models before body numbers
14G
W1-2887
W3-9792
W5-12604
F1-1771
F3-4685
F5-2061
C3-3258
C5-10335
4H
W3-7729
W5-6014
Y5-13014
F3-1617
C3-3751
C5-11445
This would refer to the trunk emblem since the hood and front emblem is covered in the chassis parts catalog.
But I suppose the hood emblem would have changed at the same body number.
Note #25
Type "B" emblem [V] used on and after body numbers and car serials in Note 24.
Per Pg #257, [Open Bodies, U S A]
Note #21
Type "A" ornament used on models before body numbers
14G
K5-7547
4H
K5-15058
Note #22
Type "B" ornament used on and after body numbers and serials in Note #21South Lompoc Studebaker
Originally posted by arkusvt View Posti haven't purchased a body parts manual as yet. the vin.# is 8323568, the body# is 4H-K5,8802.the body plate is attached by two phillips head screws. is that correct? the car was repainted with a color change 28 years ago; the plate and screws are the new color. i acquired the car from an 84 year old gent who bought it 50 years ago from the original owner; it has 29k original miles on her, with only 9k added in the last 50 years, so i have no reason to question anything, just curious. thanks for any help!
The Serial Number plate should be spot welded on and not painted. The body plate should be held on with Phillips head screws and be painted with the body.Gary L.
Per the '51-'54 chassis manual:
Type "A" aka tri-star hood emblems used on:
14G W & F body S/N G1245498 and earlier
14G C & K body S/N G1246604 and earlier
4H W, F & Y body S/N 8340196 and earlier
4H C & K body S/N 8339269 and earlier
Type "B" aka the V/S emblems start with the next S/Ns from those.
My own '53 K body is a 14G-K5 and S/N G1228619 and has the tri-stars. It was built in May of '53.
Jeff in ND
Your serial number indicates the car was built in May of 1953. That was the same month it was decided to quit putting the three pointed star on new production, but they kept them in parts stock for replacement purposes.Restorations by Skip Towne
