Hi all- There is a thread running currently regarding electric fuel pumps and I am interested in the comments some of us have made regarding priming. I did not wish to hijack the thread so I will bring my problem up here instead. I have found that my recently acquired 1962 Hawk will start fairly readily when It is parked nose pointing downhill, but if I park uphill or on ramps (with the front of the car up) it won't start. Investigating this, I found the Carter fuel pump not delivering fuel to the carb and appeared dead dry. No amount of cranking resulted in fuel coming up from the tank. I replaced the pump with a rebuilt one (even though both worked fine under a manual test I performed off the car) but identical problem exists. It seems the pump does not want to suck fuel up the line against gravity and the internal valves don't seal well enough whilst the try to pump air alone. It will only work if I manually prime the whole system first. The whole idea of an auxilliary pump is interesting me now, but I really would like to know why the conventional arrangement won't work. BTW I have no filters at all and I've also undone the fuel cap during tests. I can easily suck fuel up from the tank through a tube so I know it isn't restricted.
What's the problem?
Steve
What's the problem?
Steve
