Does anyone know of a source for the gasket that goes between the reverse light chrome housing and the fender body of a 1951 Studebaker? The original ones have hardened and crumbled. The kit is AC-2179 Strato-Lined Automatic Back-Up Light. I need to get a hold of two gaskets as I have the dual light setup. I contacted Studebaker International, but they were not able to find them.
AC-2179 Gaskets Needed
Body / Glass: AC-2179 Gaskets Needed
Tags: None
Can you make your own gaskets using gasket material? I've done this many times and had good success....you just need a set of punches to punch out the appropriate size hole for the screw, bolt, etc. For lenses I have used old computer mouse pads, for mounting lens housings to the body I would recommend using thin sheet rubber which you can get at your local hardware store...
Originally posted by jif988 View PostCan you make your own gaskets using gasket material? I've done this many times and had good success....you just need a set of punches to punch out the appropriate size hole for the screw, bolt, etc. For lenses I have used old computer mouse pads, for mounting lens housings to the body I would recommend using thin sheet rubber which you can get at your local hardware store...
Brian,
I went out into garage to look for similar gaskets and found that the 1961 Lark taillight lens mounting gasket, part number 1338883, might work (sorry I don't have a 51 backup light to test them on).
If not, there are other similar Studebaker taillight housing or lens gaskets from the 50's and 60's that could possibly work in a pinch, if you can't find the originals in usable condition.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
