Coupe Rear Window Latches
  • Body / Glass: Coupe Rear Window Latches
    Has anyone found a replacement for the spring (303682) in the rear window latches on the "C" bodied coupes/hawks??
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
    Branakeys Hardware has lots of springs, bring one up, and we'll check it out.
    Bez Auto Alchemy
      I believe Milt is referencing this bit of spring steel. Click image for larger version
      I have only seen it at swap meets as part of the latch assembly.
      Brad Johnson,
      '56 Sky Hawk in process
        Yes I am looking for the flat steel spring around half inch wide
        Milt
        1961 Hawk 4-speed
        1967 Avanti
        1961 Lark 2 door
          Has anyone found the rivets for those rear latches? 303683 and
          303684
            They won't go by part number, but if you have the dimensions, this place has about everything. Rivets, Riveting Tools and Equipment | Hanson Rivet & Supply Co
              That Spring is unlike ANY other and probably will only be found on a Salvage Window Frame from a Parts Car.
                I think I have some new springs somewhere. I'll look tomorrow. I could probably turn the rivets on a lathe, but with the time involved the price wouldn't be caso friendly.
                JT
                  A clock maker might be able to make a spring like that.
