Fan blade
  • Fan blade
    I've just been told that there were problems with fan blades on some Studies. Does anyone know about this? I'm looking for a replacement and I don't want to get another if it's going to be a problem as well.
    peter lee
    Why do you have two posts for the same issue? You can only get help if you read the responses people give you.
      I'll just leave this here: http://forum.studebakerdriversclub.c...3195-Fan-blade
        Joe your link leads back to the other thread from the same OP.
          As our cars get older, the risk of fan blade failure increases. Just ask the Model T guys (I have a 1926 fan blade that is cracked 3/4 of it's width hanging on the wall now). Stress cracks form at a rivet and over time it works it's way across the blade. If your lucky, you catch it in time....if not a nice dent in the hood or fenderwell results....or even worse, an injury if your working under the hood.
          Mike Sal
            I do read the responses. I should remove one.
            peter lee
              Someone has a fan blade for a '61-66. Does anyone know if that will work with my car?
              peter lee
                As noted above, there were a number of possible fans for V8 engines, depending on whether the car had a viscous coupling, air conditioning, etc. I have a used 4-blade fan (presumably 1556168) from a 64 289. This is the standard unit, used without any extras. You can have it for the postage. That said, if Bob Kapteyn has a new one that would fit, that would be a better choice.
                Skip Lackie
                  He doesn't - he has THREE posts on the same subject.
                    I'd delete one but don't know how.
                    peter lee
                      Info on how to reach Bob, please.
                      peter lee
                        Contact Bob: Studebaker@mac.com
