hub & drum ,59 to 64 ,new or used< that are in good cond,. that can be turned or allready turned , ask for them all the time ,any one know ,or have some , SI dont have them or other supplier's i have heard of ,any help would be great .
looking for 9'' rear brake drum's for 6 cyl lark??
Originally posted by dannyo View Postnew or used< that are in good cond,. that can be turned or allready turned , ask for them all the time ,any one know ,or have some , SI dont have them or other supplier's i have heard of ,any help would be great .Bo
Obviously ANY 9 Inch Studebaker rear Drum with 5 Lugs, for tapered axles, is going to work.
But if you are not into installing your Hub into a "Drum Only" THAT might be a problem.StudeRich
If it is complete with the Hub installed it will save a lot of frustration trying to figure out how to
R & R a Hub.
Yes, a complete used Hub and Drum Assembly, not more than .060 oversize when machined or usable as is, from a '54 Champion will work fine on a '59 to '64 6 Cyl.Last edited by StudeRich; 10-16-2017, 10:32 PM.StudeRich
9 in drum
Originally posted by dannyo View PostHi all, need the hub & drum for 59 to 64 , the shoes are 2 1/4 '' the older cars are only 2'' , this is what i need .
