I have a power shift at the shop for an overhaul. Thus transmission has an air cooled torque converter along with the air cooled bellhousing. Is this a normal set up, or has someone done some swapping? Thanks in advance
Power shift question
Transmission / Overdrive: Power shift question
Jamie McLeod
Hope Mills, NC
1963 Lark "Ugly Betty"
1958 Commander "Christine"
1964 Wagonaire "Louise"
1955 Commander Sedan
1964 Champ
1960 LarkTags: None
Nope, it should have the cooling slots, as well as the sheet metal shields on the bottom and passenger side. The torque converter will also have the stamped sheet metal "fan" spot welded to it. The converter should be stamped HRBez Auto Alchemy
