Question, did Studebaker ever use the same wheel cylinders on both the 50 champion and commander land cruiser? Everywhere I look Vendors list the same cylinder for both cars. I know on my land cruiser and in the parts catalog they are not even close to the champion cylinder.
1950 Land Cruiser Brake Cylinder
No.
The Commander/Land Cruiser used different wheel cylinders than the Champion. The rear LC/Commander wheel cylinders were also used on 810/812 Cords. That's why they were so hard to find for years before being reproduced.
The master cylinder is the same for all 50 Studebakers, as well as many other years.
Most online. I have seen many parts dealers list the same for both cars. I don't purchase brake cylinders for the commander from them, did that once. Every one I have seen are selling champion compatible cylinders as universal for all 50 Studebakers. Also see quite a few selling one cylinder for both front and rear.
This started couple years back, I needed cylinders for a land cruiser that were fairly rusty and ordered a set from I think it was Rockauto. Had to return them. Sent the rusty cylinders off and had them sleeved. No problem sense.sigpic
Barn Find
1950 Champion
Before I started
Jim Berry
Midlothian, TX
Buying them from Studebaker Vendors you do not have that problem EVER, if you state the Correct Model and Year.
Also you do not have to Pop for huge Bucks to have them sleeved.StudeRich
Originally posted by doubledaddy View PostMost online. I have seen many parts dealers list the same for both cars. I don't purchase brake cylinders for the commander from them, did that once. Every one I have seen are selling champion compatible cylinders as universal for all 50 Studebakers. Also see quite a few selling one cylinder for both front and rear.
I understand buying from a Studebaker vendor but in this case the cost is beyond reason, $60+ each from Studebaker vendors and as low as $18 elsewhere for champions. The cylinders for the 50 champion were used on several chevys, Plymouths and jeeps to name a few and as such are much easier to find. I have not yet found another brand that used the commander cylinders and at around $80+ each a sleeve at under $50 made a lot of sense, $120 a set saved and they are as good as new. I try to use Studebaker parts and quite often scrounge used parts. I have had several parts cars over the last few years and have not worried much if a part is technically correct as long as it fit and looked like a Studebaker part. I would bet that is the reason my land cruiser wound up with champion cylinders.sigpic
Barn Find
1950 Champion
Before I started
Jim Berry
Midlothian, TX
