View Full Version : Engine: R2+ camshaft valve lash
starliner62
09-27-2017, 05:45 PM
I have a 289 equipped with a R2+ camshaft. It has relatively low miles and runs great, just noisy. I contacted Phil Harris, knowing that he built the engine. He told me that the valve lash could be much tighter that a stock Studebaker cam. I went from .024 down to .018 in a couple of increments. The engine sounds better but the valves are still pretty loud.
I'm looking for opinions from those of you running this camshaft. Thanks in advance!
64studeavanti
09-27-2017, 07:29 PM
The valve train noise is likely the nature of tge beast
It is my understanding that the r2+ is similar to the isky st5. I have the st5 in one of my Avantis. Isky recommends .018 valve lash. It is pretty noisy.
Chicken Hawk
09-27-2017, 09:15 PM
I don't know where Phil is having these ground but when I was in the parts business and had them made, the lash could be as low as .010" hot. I advised people to start out at .020" and go down a couple thousands at a time until they were happy with the sound as far as noise. With power brakes I wouldn't go that tight though.
Ted
09-28-2017, 12:07 AM
Yes, when reducing the valve clearance, the clicking noise is reduced, but it's not just about the noise. Tightening the lash increases the cam duration and overlap; the idle gets slightly rougher, vacuum is reduced, low speed torque is slightly reduced, as is fuel economy. The high RPM power is slightly increased. It's all a tradeoff and as Ted says, find your own best compromise.
jack vines
starliner62
09-28-2017, 03:53 AM
Thanks guys. I am aware of the trade offs when reducing the valve lash, just wasn't sure of how far to take it.
Quentin
09-28-2017, 07:56 AM
Ditto with the engine - new build, 0.040 rebore, with Phil's cam - valve train set up to factory spec, cant tell you exactly what that is as a friend set it up, but we went by the book; it is noisy, i.e tickety tickety, and it worried me for a while, noisy compared to other brands.... however power is solid under acceleration with the idle as good music.
Endl98
10-14-2017, 08:38 AM
I set mine on the tighter end at .010 it's pretty quiet, cam is crazy choppy with open exhaust. Feels good on the street.
Buzzard
10-14-2017, 12:56 PM
I have a Racer Brown custom grind off an Avanti 288 degree factory camshaft. It works terrifically in my R4 Clone and the settings are:
Intake: .012 Hot
Exhaust: .014 Hot
Net lift .485
Duration: 266
Max RPM: 7000
I would classify the valve train noise to be about the same as the 60's Chev 365 HP Solid lifter 327 L76
Sorry I can't seem to be able to post the Racer Brown cam card.
Bill
