View Full Version : R1 water pump pulley
Jeffry Cassel
09-27-2017, 08:39 AM
someone (champstude64@aol.com) (?Ken Fedor) had a water pump pulley for R1 on the swap page. Can't reach himso if you see this and it is still available, I am interested. Jeff Cassel (jccatwb@gmail.com)
09-27-2017, 04:54 PM
It's Sold, I already asked and we are weeks TOO late, for most all of it.
64studeavanti
09-27-2017, 05:01 PM
Jeff, Rich,
If you need Avanti water pump pulley, I have a couple of spares.
Jeffry Cassel
11-25-2017, 08:24 AM
Jeff, Rich,If you need Avanti water pump pulley, I have a couple of spares.Rich ; Just now saw your message. I would be interested in the pulley to try on my 64 Hawk with AC. You can send me a pm or my email is jccatwb@gmail.com Jeff
sals54
11-25-2017, 12:01 PM
Here's one on Sacramento Craigslist for $50
https://sacramento.craigslist.org/pts/d/studebaker-avanti-water-pump/6400040688.html
64studeavanti
11-25-2017, 01:22 PM
Jeff,
I have a couple for Avanti. But I don't believe they will work on a stock JT/JTS.
sals54
11-27-2017, 01:08 AM
Are they not the same??
64studeavanti
11-27-2017, 01:48 AM
I believe JT/JTS used "regular" water pump pulleys. I can find no different part numbers in the JT section of the chassis manual. The Avanti pulley is a heavy cast iron affair with 3 grooves. One is for the alternator. The other 2 are for S/C if so equipped. If A/C car, one is unused. The JT/JTS crank damper has a groove on it so the stock water pump pulley and altenator can be used.
packardHawk58
11-27-2017, 01:55 AM
Henry, you can run a regular pulley but a JT/JTS factory pulley is 6 5/8 dia so it will spin the pump quicker compared to a 7" regular.
I have one if you want an original.
SScopelli
11-27-2017, 10:22 AM
Be careful in changing out your water pump pulley to the R, smaller diameter, if you have AC. If the AC belt rides on accessory pulley on the water pump you will need to change it too.
Its all about ratios.
If your Crank pulley has various diameter grooves for each of the drive accessories, you need to keep the ratios. You can not spin the water pump faster while keeping the AC the same ratio. It makes a horrible sound.
Jeffry Cassel
11-27-2017, 05:34 PM
never seen a cast iron water pump pulley; pump wouldn't last 100 miles with all that weight on it. I want to spin the pump just a bit faster to see it it will run a little cooler on a warm summer day. Not talkin bout the crank pulley. Packard Hawk: if you have one how much do you want for it.?
64studeavanti
11-27-2017, 07:43 PM
Jeff,
You could also try the heavy duty 6 blade fan with or without viscous drive. I also have the smaller pulley (non-Avanti) as well as 5, 6 and 7 blade fans. I have 6 blade with or without viscous drive. The 5 and 7 are with viscous drive.
packardHawk58
11-28-2017, 04:53 AM
Jeff, I would want 50.00 bucks for it but it might be another 25 bucks shipping from OZ.
You might be able to obtain one from Dave Thibeault.
If you get stuck Pm me and we can work it out.
Brian
mbstude
11-28-2017, 02:49 PM
Is this an Avanti water pump pulley?
We've got a couple of them but I wasn't confident enough to put a part number on them.
68870
68871
64studeavanti
11-28-2017, 03:18 PM
Matt, sure looks like it. BTW, SI and your site have an incorrect description for 1563110. This is an aluminun pulley with 2 grooves for A/C cars that came as part of an idle cooling improvement kit referenced in service letter R-1964-4 dated Apr 24, 1964.
Both sites say this is a 3 groove pulley.
This service letter is dated 4 months after the line shut down. I think it is highly unlikely that any Avanti came from the factory with this kit installed.
Cowtown Commander
11-28-2017, 04:19 PM
The kit also came with a new heat send unit. I always wondered which reduced the "temperature" more, the new pulley or the new temperature sensor.
mbstude
11-28-2017, 04:43 PM
We likely copied the info from SI’s catalog for our inventory file. I’ll make sure it gets fixed. Thanks!
64studeavanti
11-28-2017, 05:01 PM
Matt,
You should double check the pulley. I believe Lionel Stone was making some out of aluminum. These may be the ones everyone has for sale. Sure would be nice to know for sure.
Alan
11-28-2017, 05:20 PM
These are Stones pulleys
64studeavanti
11-28-2017, 05:28 PM
Alan,
Can't tell for sure from the pictures - are the grooves different sizes?
Alan
11-28-2017, 07:12 PM
64, The belts I run are 1548509 which is 45 1/2" x 13/32" x 38 degree for the alternator/fan. And 1555320 which is 56" x 7/16" x 36 degrees. There are 3 grooves and the pulley is stepped, will put up a pic from the side tomorrow.
jts359
11-28-2017, 08:04 PM
I have 1 of those pulleys from the factory kits , Its aluminum, NOS, and 80.00 , Thanks , Ed
64studeavanti
11-28-2017, 08:43 PM
Ed, is yours 2 groove or 3? My 64 has the kit installed and it has 2 groove pulley.
jts359
11-29-2017, 07:28 AM
Mine is two grooves , Ed
64studeavanti
11-29-2017, 07:35 AM
Ed,
Thanks. I was always confused since everyone seems to be selling aluminum 3 groove as the pulley from the kit. Mine was installed when I bought the car over 15 years ago and I always assumed it was original.
Alan
11-29-2017, 03:11 PM
Here is the pic. I promised to send in #21 above.
