View Full Version : gas gauge
jrlemke
09-22-2017, 06:40 PM
What is the ohm rating for a '61 Hawk gas gauge? Thanks -Jim
lumpy
09-22-2017, 09:08 PM
should be 240 empty 33 full
jrlemke
09-22-2017, 09:29 PM
Thank you! Jim
jrlemke
09-23-2017, 07:23 PM
'nother question! my gauge has been in and out of the tank so many times I don't know now if float should be toward the back or the pass. side. Which is correct?
09-23-2017, 07:52 PM
It will only actually "FIT" the screw pattern correctly in ONE position, that is with the Float to the Right so it cannot move on starting and stopping, only the Fuel can.
Use a New Gasket and Copper Washers under the 5 Screws.
thunderations
09-23-2017, 10:21 PM
What you are dealing with is the "Sending Unit", not the gauge. The gauge is in the dash.
Studebakercenteroforegon
09-24-2017, 12:14 AM
Unless you are reading a Studebaker Chassis Catalog. Group 0307-20 Gasoline Gage (Tank Unit)
"Gage" is so spelled by Studebaker.
surfcat2000
09-30-2017, 05:46 PM
Question I bought a 55 flat window wagon that has a 327 chev , 12 volt system and a custom built gas tank. The gauge reads full all the time when the key is on. it goes to empty when key is off. I dropped the tank and re did the ground for a good connection. I touch the wires together and get full. wires apart gauge reads empty. It has a universal vdo sending unit 10 to 180 ohms. with the float down it reads empty any movement of the float upward reads full. Is this the wrong sending unit.Thanks
lumpy
09-30-2017, 06:55 PM
Does it have the original stude gas gauge?
surfcat2000
09-30-2017, 07:07 PM
yes it has the one in the dash
jrlemke
09-30-2017, 09:08 PM
Should read 240 empty/33 full. Wrong sending unit. -Jim
lumpy
09-30-2017, 09:34 PM
You can buy an SW universal sender from speedway or any other speed shop. speedway spells out pretty clearly if you need a right hand or left hand sender. the sender comes with instructions for setting up your float level.
surfcat2000
10-01-2017, 09:41 AM
Thank you. That's what I thought.
surfcat2000
10-01-2017, 09:46 AM
Thanks
Thanks. I ordered a Wema with a sliding float.
Pckstude
10-11-2017, 11:51 PM
I just replaced the gasket on the sending unit in my '65 Wagon. I made the gasket myself from fresh sheet of cork material. I also replaced the cork float with a plastic float from a carburetor shop. When I put it back together and then drove the car 6ft or so then slammed on the brakes in both forward and reverse to slosh the fuel around, I still had a small leak from the screws(?). So I bought some very small "o" rings to go on the screws beneath the washers, so the "o" rings would contact first. Then I repeated the back & forth driving. I think the leak is fixed. The jury is still out.
BTW does anyone sell new sending units?
10-12-2017, 02:19 AM
Those 5 screws originally had Asbestos filled Copper crush WASHERS under them.
Gasket Sealer on the screw threads may help.
Let's just hope that the "O" Rings are Ethanol resistant!
Pckstude
10-14-2017, 11:51 PM
Thanks for the info.
