Guys, Here is a device that might give a power brakes feel without the vacuum booster bulk. What it does is to multiply line pressure, but only at higher pressures. That way, not much more volume of fluid (pedal throw) is needed to get higher line pressures. Have a look, it might be a good solution for high pedal pressures on a non-power assist car. Especially if you have a rumpty rump cam, with low vacuum, so a vacuum booster is not too effective, or if you want to get rid of the bulk of the vacuum booster. Have any of you tried one of these yet?
Power brakes without the booster?
Originally posted by Treblig View PostMore pedal travel required!! As long as you have sufficient room.
trebligCorley
Originally posted by Corley View PostThe whole point of this thing is that it doesn't take nearly as much extra pedal travel as going to a smaller diameter master cylinder would. So yes, a little bit more pedal travel, but not much.
treblig
Originally posted by Treblig View PostI wasn't saying that it's a bad idea.........I was just pointing out that you have to be sure that you have sufficient pedal travel in order to use this special master cylinder.
treblig
I don't mean to pick on you, but wanted to clarify terms. As to a bad or good idea, only feedback from an install will tell that tale.Corley
I see 3 Ports, unless there is a hidden one, that could be a problem.
So do you Guys think it has 2 Ports IN and One Out or vice versa?
If it were 2 IN and 1 OUT, it would defeat 4/5's of the purpose of the Dual Master Cyl.
That IS a really neat Idea though, as I would hate having a Big Hydrovac under the hood on a C or K as it would be required with most Disc Setups if you want to stop sooner not later.
I also could not deal with a pile of junk hanging under the floor either, like a Dual M/C or a Mini Street Rod Booster and a bucket of Lines.Last edited by StudeRich; 09-20-2017, 01:51 PM.StudeRich
Originally posted by StudeRich View PostI see 3 Ports, unless there is a hidden one, that could be a problem.
Or, it could be 1 in, one boosted out, (probably to the front brakes), and one unboosted out (probably to the rears). Just guessing at possibilities here... The reason for that thinking is that a lot of hot rods (and other cars) have to use a proportioning valve to limit pressure on the rears anyway.Corley
I see that it got a new product award 13 years ago so there must be many installs out there to check on. Maybe not on Studebakers.Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
