View Full Version : Avanti Frame now listed on EBAY
sals54
09-17-2017, 06:06 PM
Here is the listing for the Avanti frame/chassis.
http://www.ebay.com/itm/272851494397?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
lumpy
09-17-2017, 11:12 PM
Just curious .. My lark is just about finished, does an avanti chassis with the x member fit under an early lark sedan?
sals54
09-18-2017, 02:37 AM
I don't know for sure, now that you mention it. The frame is the same and the wheelbase is the same. Now then, the convertible Lark frame is the same, so perhaps the sedan would fit also. Others may chime in...
LarkTruck
09-18-2017, 06:56 AM
The frame will "fit", but the tall saddles on the rear will need to be removed, and the last six inches of frame rail and original Lark rear cross member that were cut off at the factory put back on. Also the large side outrigger brackets, firewall mounting brackets, radiator support brackets need to be whacked off. And the modified front leaf spring bracket needs unmodified. And, if you plan on installing the traction bars (radius rods) the Larks use a different front mounting bracket for body clearance. This work needs done even for use on a convertible. Just to mention a few items.
Oh yeah, and you will need to use the Lark body/rear engine support cross member as well.
JS
Jessie J.
09-18-2017, 11:38 AM
Easier to just stick with a Lark frame for a Lark. If more strength is desired, welding in additional cross-members or an X member is not all that big of task. Any real hard core performance activity is going to require a certified full roll cage no matter what the chassis origins. Might as well start with the lightest 6 frame and weld in 200 lbs. of strategic reinforcements. JMOP
lumpy
09-18-2017, 09:35 PM
Thanks for the info guys:!!: don't want to hijack this thread.. good luck with the sale Sal!
SScopelli
09-19-2017, 10:19 AM
671646716567166671676716867169
Here are some of his pics from feeBay
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=67164
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=67165
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=67166
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=67167
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=67168
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=67169
From another thread
sals54
09-19-2017, 04:27 PM
Thanks for posting the llink to the pictures. I forgot to list the fact that the frame also has a very nice exhaust system installed in it.
