53 Champion VIN??
There is Technically no "VIN" Number anywhere. The Serial number on the Serial number Plate welded to the Driver's Door Post serves as a VIN Number for Registration purposes.
This is only a Plant identification, Engine Cylinder # and sequential Line Number of all either 6 or Eight Cylinder Cars Mfg'd that year Model.
No "Other" info is available without the Production order which IS available here: https://studebakermuseum.org/
This Link is From our "Main Page" under "Resources".
There is also the same "Secret" Serial Number on the Rear Lower Flange of the rearmost Frame Crossmember, lightly stamped and may be rusted too much to see.StudeRich
Originally posted by StudeRich View PostNo "Other" info is available without the Production order which IS available here: https://studebakermuseum.org/ .Brad Johnson,
'56 Sky Hawk in process
I guess I could have said: NO other Significant information is available without the PO.
The Body Tag will only tell you what you already know and can see, it's a Starliner Hardtop which only came in the one K5 "Regal" Trim Level.
The sequential number on the body line is definitely not very Significant.StudeRich
Originally posted by dand1 View PostWhere on the K body is the VIN located???
Two numbers may have been used as a "VIN". The one most currently accepted is the Serial Number, which is located on the driver's door jamb between the hinges. The other, which was used by many states, is the engine number.Gary L.
Thank you for your feedback, however the sales agent is looking for a certification that the post sale DMV will accept for registration. Ideas? DMV rulings Font style exhibits for Calif, examples of DMV matches of titles to serial number on engine block, ...
My 53 was made in Los Angeles with vin 1056 193[ATTACH=CONFIG]67701[/ATTACH] (ooops upside down!) please compare title to photo nbrs to assure they are same.
Thanks, Dan DeHaven, 7034701300
If you have trouble with the I being used as a 1, there is another topic here that gives the reference for the documentation on this.Gary L.
Originally posted by dand1 View PostThank you for your feedback, however the sales agent is looking for a certification that the post sale DMV will accept for registration. Ideas? DMV rulings Font style exhibits for Calif, examples of DMV matches of titles to serial number on engine block, ...
As noted above, in 1953 some states (eg, Calif) used the engine number for registration, and many others used the serial number riveted to the A pillar. If the vehicle was first registered in Calif or another engine-serial state, and was never registered in another state, then the engine number will be in the VIN box on the title. If the vehicle serial number was used, then that is probably the number on the title. You can obtain a copy of the original production order from the Stude National Museum. It will show both the vehicle and engine numbers and has been used by many people to prove to a DMV that the numbers are original to the vehicle.Skip Lackie
Calif. has and will accept this Engine Number as a correct "VIN" Number for Registration if you get a Manager who understands the Calif. Statutes and registration procedure.
OR: They also will inspect your Serial Number if you ask, and with a Production Order in hand to PROVE that this THIS Car with it's Serial Number, came with THIS engine.
Then it can be registered by it's Serial Number, which they will agree is much better than the Engine Number which likely could get changed at any time.
Either way, that I.D. Number will be placed on your New Calif. Title and one of them of course must match the Old paperwork/Title paper you have for proof of ownership by means of the former owner signing it off and verification of Price paid and or a Calif. Bill of Sale Form.
I have been there, done that!
Also Note that your Engine Number is: 1056195, not 93!
Is THAT what you are trying say in Post #1 maybe?
UPDATE: I see you are in Virginia? The same should still apply if ANYONE there has a Brain!Last edited by StudeRich; 10-24-2017, 03:36 PM.StudeRich
Originally posted by StudeRich View PostCalif. has and will accept this Engine Number as a correct "VIN" Number for Registration if you get a Manager who understands the Calif. Statutes and registration procedure.
UPDATE: I see you are in Virginia? The same should still apply if ANYONE there has a Brain!Gary L.
