View Full Version : Engine: Location of #1 cylinder on distributor cap model 31
willyj
09-13-2017, 07:40 PM
I need to know the location of the #1 cylinder on the distributor cap of a 337 straight 8 engine on a 31 presdent 4 seasons roadster. Is it the front of the distributor cap or the rear?
Dwain G.
09-13-2017, 11:35 PM
This may help...........
66999
Neal in NM
09-14-2017, 08:55 AM
Actually, it can be anywhere you like it to be. Wherever the rotor is facing when the #1 cylinder is at TDC on the compression stroke is where the #1 spark plug wire goes. Neal
bensherb
09-14-2017, 06:55 PM
[QUOTE=Neal in NM;1073630]Actually, it can be anywhere you like it to be. Wherever the rotor is facing when the #1 cylinder is at TDC on the compression stroke is where the #1 spark plug wire goes. Neal[/Q
​EXACTLY!
If it's not where you want it to be, just set the engine to TDC cylinder #1 compression stroke, remove the distributer and reinstall it with the rotor pointing to where you want the #1 wire to be.
