View Full Version : Installation tools for upper and lower control arm bushings ???
14x7
09-07-2017, 03:17 PM
Does anyone know someone who has all the tools for disassembly and assembly for upper and lower control arm bushings for a 1955 president C body???? Thankyou. Mike
09-07-2017, 03:58 PM
Please go to your SECOND Post before anyone does and use the Delete String/Post in the "Go Advanced" Mode to Delete it.
I will answer this first one. Most people use basic Tools for the INNER "A" Bushings instead of the "Factory J Tools" that cannot be found.
A Hydraulic Press, a BFH, an Air Powered chisel hammer, a Torch etc. etc.
The Upper "A" Arm spreader tool for doing the Upper, Outer Pins IS available at: http://studebakerpartsonline.com
You can easily MAKE the Inner Arm "Spacer" tool to prevent crushing it from a piece of Pipe if needed.
53commander
09-07-2017, 05:26 PM
All three of these suggestions are what I used when I did my arms.
61Lark
09-07-2017, 07:54 PM
I used the tool in the link below with an air impact and it made the job much easier.
https://m.summitracing.com/parts/sps-40910
57pack
09-07-2017, 10:08 PM
I used a a frame bushing tool made by OTC that worked very well. OTC-7068. I've noticed cheaper versions offered by off shore companies.
64V-K7
09-07-2017, 11:26 PM
Check out
http://www.studebaker-info.org/Tech/Suspension/bushing/bushingtool.html
The bushing tool is the way to go..
Place the A-frames in a vice and destroy the old bushing rubber with a drill bit, punch the old shells out, clean the frames up and use the tool to install new bushings.
14x7
09-08-2017, 04:37 AM
I can't figure out how to delete second post.
swvalcon
09-08-2017, 07:21 AM
I took two pieces of angle iron cut just right and tied together along with a press to put mine in. Worked great. No I have them marked and put away if I ever need them again.
14x7
09-10-2017, 09:18 AM
Are the pins called a trunion? Why ? Do the pins need to be replaced , if the control arm bushings are shot.
swvalcon
09-10-2017, 12:47 PM
14x7 Not sure what your referring to by pins but if only the bushings are bad that is all you need to replace. The uppers you can replace with K-5196 gm's but the lower you will have to use studebaker.
09-10-2017, 01:27 PM
/Cut/The Upper "A" Arm spreader tool for doing the Upper, Outer Pins IS available at: http://studebakerpartsonline.com
If the Upper Outer Pins have excessive wear, Yes replace them, otherwise you do not HAVE to.
I and Studebaker call them "Pins and Bushings", only Chuck Collins calls them Trunions, all the same. :)
14x7
09-11-2017, 12:43 AM
This forum is the best....
