View Full Version : Steering Steering column through firewall seal
53commander
09-05-2017, 01:59 PM
For my '53 Commander I have a new rubber steering column seal but in the book it seems to also show another piece. It's referred to as "Grommet, Steering Post Dash w/o P/S. Part number 298804. So my question is would this be another seal between the rubber seal and firewall? Does it mount inside or outside? Can I fabricate something and what's it made of?
Thanks,
Rich
09-05-2017, 02:59 PM
Doesn't your Manual Steering Section of your Chassis Parts Catalog SHOW a good Picture/Drawing of the Seal in question?
That would not only show it's shape, but also it's Location. ;)
53commander
09-05-2017, 06:48 PM
Problem is the car is an hour away along with all the manuals. All I have with me is a '55-58 Chassis book and I don't see anything under steering. I know these questions might seem trivial but I only have a few days every couple months to actually work on the car so I like to have all the info I can before I work on it. Last weekend all work stopped because I didn't have the right starter solenoid or shift linkage. That is the only thing hanging me up from moving the car under it's own power. So now I don't want to do the final install on the column if I can't be sure it's all correct. Trust me I only ask when I'm stumped, you guys would run me outta here if I asked every question I had ;)
09-05-2017, 08:28 PM
OK, the '53-'58 Body Parts Catalog says: Picture 2339-8 is the "Seal and Collar" for '53 it's 298802X1, '54-'56 = 306910X1
The "Grommet" is actually the SAME Large square shape as the rubber Seal & Collar, but appears to be a Fiber or Foam Insulation/sound, heat Seal.
the 2339-6 = 298804 for '53 and the 310146 is for '54-'56.
ALL without Power Steering on C & K.
The reason there are SO many different shapes of these, other than P/S or not, is the notch-out in the upper corner for the different Parking Brake locations thru the years.
doofus
09-06-2017, 06:14 AM
Rich, my last 2 driver,s got a seal made from jute under padding for carpet. sandwiched between the rubber column seal and the firewall. Luck Doofus
tim333
09-06-2017, 04:11 PM
I had a rather large opening on my 57 Commander. Put a piece of cardboard on the inside for temporary backing and sprayed the stuff the guy advertises to stop leaks on a screen door-bottomed boat, dried nice and hard. Looks good cuz it's black and no more air or water leaks thru the firewall at the steering column.
skyway
09-06-2017, 05:14 PM
I sorta hate to admit that in the 1970's we used to buy NOS ones, and make a cut thru the rubber and metal core, so's to slip them over the column.
53commander
09-06-2017, 10:37 PM
Two very good ideas, thanks.
Saves the hassle of removing the column anyway. Lucky for me my column is only loosely bolted in until I'm sure it's right.
