View Full Version : Body: Champ window regulator
Hoghead
09-02-2017, 09:46 AM
Is a 1960 Champ window regulator the same as a Lark or another Stude car?
GTCruiser
09-02-2017, 10:08 AM
Same as earlier Larks, '59-'60, but not necessarily later sedans.
Hoghead
09-02-2017, 10:35 AM
Thanks
Do you have a part number
Is this available as I cannot seem to find them. A power window conversion might be a solution?
62champ
09-02-2017, 11:15 AM
My 7e parts book shows regulator 1343100 (R) and 1343101 (L). Earlier ones are 1314350 (R) and 1314351(L).
Those doors are the same as sedans through '62 - so as long as the mount holes and lower window bracket are the same, you should be good. Good luck.
55s
09-02-2017, 12:05 PM
I have good used. $100 + shipping.
Studebakercenteroforegon
09-02-2017, 12:13 PM
1962 and later Champ pickups used the single stud regulator that was used only on 1962 Lark sedans. (Y, F, and P body)
Hoghead
09-02-2017, 08:38 PM
Confused now
Is my 1960 Champ the same as a Lark to 62?
62champ
09-02-2017, 09:35 PM
Confused now
The door on your '60 Champ and a 1962 Lark 4 door sedan (or '62 Champ) is essentially the same. In 1962, the Lark and Champ went to a single stud on the regulator and window bracket at the bottom of the door window. '61 and earlier had a dual stud regulator and door window bracket. As long as you have a regulator and window bracket that mirror each other, you should be good.
So if you get a regulator for a '62 Lark, make sure you get the door window bracket or else that regulator will not work with your original lower door window bracket.
The door on my truck came off a '62 Lark 4 door sedan - but because the truck was a '62, the original window and bracket out of the truck fit on the Lark regulator.
https://i.imgur.com/8U3dwlO.jpg
Hoghead
09-02-2017, 11:13 PM
Got it now - thanks
