Can someone tell me what the correct 6 volt flasher unit I should have for a turn signal setup on a 1951 Studebaker Land Cruiser? I currently have four 6 volt units in my possession:
1 2507 (P229D) Made by Ideal NOS unit
2 P229D Original unit that came with the a wire harness that I salvaged pieces off of
3 535 Bronze colored Tung-Sol Flasher in my parts bin
4 535 heavy duty bought brand new from auto parts house
I posted several weeks back with problems blowing the 14 amp inline fuse. I have since taken care of that problem and now face the following issue:
- Both right and left rear turn signals work (flash) when lever on column is engaged
- No pilot lamps (arrows) in the speedometer housing
- No front turn signals from the parking lamps
The above only works when I use flasher unit 2 or 3. If I attempt to use the other two flasher units I will not get the following:
- Both right and left rear turn signals stay on solid (will not flash) when lever on column is engaged
The fact that I am getting this reaction leads me to believe that I just have bad luck buying flasher units and can’t find one that works properly. I will not eliminate form the realm of possibilities that: “I just don’t know what the hell I am doing” but I would like to learn how to get through this. I have verified that the light bulbs to the pilot lights and to the parking lamps are good I have also verified that the flasher connector is connected correctly:
“X” = battery via ignition
“P” = Pilot lights in dash
“L” = Load (turn signal control)
