Ever since I got my 52 from Leonard's son it has had a slight leak at the bottom of the 2 bolt chrome thermostat housing. The leak was more of a nuisance than a problem since I could drive the car for hours without losing enough coolant to worry about. I finally decided to remove the part and see what the problem was.
I expected the gasket to be faulty or the base of the housing to need a little filing to flatten it. Wrong! This one is way beyond fixing. I don't know if it really shows in the pictures, but I was amazed at the amount of curve in the base. I was also surprised to see that this was the type of housing with an O-ring in the base because I could see the edges of a flat gasket sticking out. There was also a fair amount of orange silicone on the surface. I have found other things where it appeared that Leonard was trying to get something done so he could drive the car and never was able to get back to do it right.
Anyway, the mystery of the leak is solved, but I have to get a new thermostat housing. I suppose one made for a fat gasket would be better. Is this correct? In any case I plan to find a molded hose to replace the flex hose on there before. A stock hose will not work with this water manifold.
