What is the procedure? thank you cheers jimmijim
Trans fluid check----- 63 Flightomatic
Transmission / Overdrive: Trans fluid check----- 63 Flightomatic
sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** memberTags: None
Warm up the engine and transmission,
car on level ground
block the wheels
engine at idle in drive
check the dipstickLast edited by RadioRoy; 08-24-2017, 11:37 AM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
It will be a little easier than the '56-'60 procedure posted by Christophe since it is a '63, it will have the underhood Dipstick but everything else is the same of course except remove the Fill Tube to drain the Main Case if draining it using modern Ford Type "F" Fluid, or if not available; Dexron III Mercon will give a softer (more slip) shift.
It IS important to remove ALL of the Fluid by draining the Converter, which we are fortunate to be able to do as most "Other" Cars do not have a Drain Plug.StudeRich
Thanks to all those who replied. cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Originally posted by StudeRich View PostIt will be a little easier than the '56-'60 procedure posted by Christophe since it is a '63, it will have the underhood Dipstick but everything else is the same of course except remove the Fill Tube to drain the Main Case if draining it using modern Ford Type "F" Fluid, or if not available; Dexron III Mercon will give a softer (more slip) shift.sigpic
