I have located an engine that has an id of P73102. Says it came out of a 58 truck. It has a three speed w/overdrive. I have searched the data base and it has the 289 having a PC code. Is this engine a 289? It has a 4 barrel manifold and carb.
May be correct engine?
"P" stands for President 289, "C" = Canada.
P73102 is not a Canadian PC, it's an 1960 Hawk 289!
Quote from our Chart:The "Truck" mentioned had a CAR Engine."P-70,501 1960 Hawk 60V 2892"
Also, if you bought that one you would want to know if that "T-85" is a T-89 with Low Truck Gears in a "T-85 Case which is how ALL Trucks were.
OR, what Trans IS it, a light weight (Med. Duty) T-86, Long or Short Tail maybe??Last edited by StudeRich; 08-23-2017, 11:18 AM.StudeRich
Went ahead and purchased the engine. They had video of it running. Pulled it for a LS1 engine. Has a four barrel Manifold and Carter carb. Short shaft three speed. Engine is complete with generator.51 Studebaker Starlight State Commander Coupe
53 Studebaker Starlight Regal Commander Coupe
62 Volvo PV544 Sport
OK cool, now re-read Post #2 and read the raised Model Number on the forward, Right side of the Main Trans. Case to find out WHAT you got.StudeRich
Looks like a T-86 3 speed Overdrive, you will probably find the Truck Clutch Housing has been drilled and tapped to fit the Bolt Pattern of the Car Trans. we now know the Engine is a '60 Hawk 289.StudeRich
The pictures are cut off by the transmission output shaft. Is it a long tail shaft (58 and newer) or a short tail shaft (57 and older)?
Pull the top cover of the transmission. Are first gears straight cut or hypoid/angled/slanted?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I in Post #3 you said it was a SHORT Tail Trans.
So IF you had a Car Clutch housing, it would be very close to a bolt-in to a '53 Commander, BUT you say you have a DG-250 Automatic, that would require a correct DG Converter Housing to be dialed in to the 289 Block and the Long Crankshaft to Flywheel Bolts be replaced with Short ones by pulling the Engine Oil Pan and Rear Main Bearing Cap.
But the bigger question is what Trans. is the CAR set up for?StudeRich
Here are the pics of the transmission. I am looking to use the engine for my 51 Commander. The 51 has a 232 V8 and Automatic drive. I was thinking of placing the 289 in it and I have a DG250 transmission.
On an interesting side note this was the heater control valve setup on the 289. There were some ACE hardware special piping used.51 Studebaker Starlight State Commander Coupe
Don't discard that truck bellhousing, or transmission. Any fellow Studebaker owner wishing to install a V8 in a six cylinder C-Cab would appreciate the truck set-up. Especially, since it has the truck engine mounts attached.John Clary
