View Full Version : Electrical: Head Light Switch Fuse
Kato
08-21-2017, 10:09 AM
I replaced what looks to be the original head light switch in my 62 GT a month or so ago because the lights were sometimes flickering and putting upward pressure on the switch handle stopped this. Last night I was driving home after a very nice cruise and had the headlights on for perhaps 15 or 20 mins when they simply stopped working. No sound or obvious surge or anything. I still had signals and brake and back up lights. Fortunately we were close to home.
I pulled the switch out and soon found that the fuse that is attached to the switch was the problem. Fortunately I had kept the old switch and was able to use the old fuse and got it working again. As this fuse appears to be the original, or at least has been in the car a very long time, and has never blown I am puzzled as to why the new one only lasted a month! I have made no changes to the lighting system since installing the new switch. The car has halogen head lights and LED signal/marker lights. I bought the switch from Chuck at Studebakerparts.com.
Has anyone had problems with these fuses blowing? Any suggestions as what to look for considering no changes were made and the original fuse was in there a very long time? Could it just have been a poor quality fuse with the new switch? Can these fuses be purchased separate from the switch?
Appreciate any thoughts or advice. Kato:!:
6636366364
41 Frank
08-21-2017, 11:10 AM
That is not a fuse, it is a circuit breaker and will reset automatically when it cools down. You may have a short or too much of an amp draw on the system.
Ross
08-21-2017, 12:19 PM
I am finding on many of these old cars that the circuit breakers do not have the capacity they had when new, possibly because of oxidation of the contacts within. They will flip off with no real cause, and more so on a hot day. I now make it a regular practice to install a new circuit breaker whenever there is the slightest cause. They are (mostly) universal in size and easily available. Get one with the same amp rating listed on the case. They are only $12 or so from Napa and well worth it.
Kato
08-21-2017, 12:34 PM
Yes I have since learned that! Unfortunately it did not reset even after several hours. Can't explain the cause as nothing has been altered but I'll see what happens with the original breaker on the switch now. Thanks.
Kato
08-21-2017, 12:38 PM
Very good to know! The strange thing is this was a new switch and breaker. I had never had a problem with the old breaker so for now I have put it on the new switch. I'll look into a new one at NAPA as you suggest. Thanks.
Dwain G.
08-21-2017, 12:54 PM
Flip the rug back and inspect the dimmer switch and wiring. Very often this is the cause of what you are experiencing.
jackb
08-21-2017, 01:47 PM
the original switches will not handle halogen headlights, especially if you go to Hi beams. Too much capacity. A case can be made that the new (NOS) switch had already oxidized from shelf dis-use. Follow suggestions above...
thunderations
08-21-2017, 03:13 PM
You may need to add a relay in the system and use the switch to activate the relay. That takes the heavier draw from the halogens away from the switch.
bensherb
08-21-2017, 07:12 PM
Check your halogen bulbs. They come in many different wattages these days. 55/65 watt should be ok since the old 6014 incadescent that was used for decades was also 55/65 watt. Anything more just might be too much for the system.
Kato
08-21-2017, 09:01 PM
Thank You for all of these tips and suggestions. I will look into all of them.
Kato
Kato
08-21-2017, 09:15 PM
I just checked the bulb and it is rated 65 watts for high beams and 35 watts for low. You are saying this should be OK?
bensherb
08-22-2017, 03:02 AM
Yeah, it shouldn't be drawing any more power than the original incandescant sealed beams. If there's a problem it must be elsewhere. Could just be a bad breaker, as was earlier mentioned.
The head lights are the only bulbs I did not change to LED's in my '62, consequently, they are the only ones I didn't measure the current draw on, so I can't tell you what it actually is; but if you do the math, the low beams should draw around 6 amps and the high around 11 amps, given the wattage's you posted.
Kato
08-22-2017, 08:49 AM
That makes sense as the breaker is a 20 amp. The tail lights being LEDs should have much less draw than the originals so as you say the problem must be elsewhere. When I shake the faulty breaker you can hear something metallic inside as if something let go. It could very well have been a defective breaker and nothing more or possibly the dimmer switch might be the culprit as I was switching from high to low beam a lot when they quit.
Thanks again!
az64stude
08-22-2017, 08:56 AM
You may want to see how many amps your pushing. I would stay with OEM headlights but its always fun to try different things. What ever you do get that corrected its not fun when your headlights go out. You can swap the breaker with a larger one but make sure your circuit can handle that. Remember your high beam is going to draw the most amps, also do check all connectors for good contact including grounds. GOOD LUCK
christophe
08-22-2017, 09:49 AM
Don't forget that you already have in your car a very handy and useful amp meter. Thus, you can check how many ampères are drawned by your headlight. This is obvious but I have a tendancy to forget that myself.
Corvanti
08-22-2017, 01:08 PM
i installed halogen headlamps in my Avanti with no problems. if there is something rattling around in the circuit breaker, that's probably the problem. i'd go to NAPA, as stated in Post# 3 and get a newer one. also as others stated, check your dimmer switch and check/install headlamp relay(s).
Kato
08-22-2017, 05:42 PM
I came to that same realization today when I was out looking at the dimmer switch, which seems fine. With the high beams on it is drawing about 13 amps and about 9 with low beams. The breaker is a 20 amp breaker so it seems to me that the halogens should be fine. I'm really starting to suspect a faulty breaker, fingers crossed!
Kato
08-22-2017, 05:46 PM
Yes, I am very suspect of the breaker. The old switch and breaker were in the car for years with no problems running the halogens so unless there is a faulty relay or an intermittent short somewhere I'm pretty sure it was just the breaker. I'd hate to lose the halogens, much better lighting than incandescent head lights!
bensherb
08-22-2017, 06:12 PM
I would stay with OEM headlights .
If you can still find OEM type incandecsent sealed beams you're doing better than here in California. Here, incandscent sealed beams haven't been commonly available for 25 years, they're all halogen now. It's actually starting to get more difficult to even find any round sealed beam now. I'm sure when I have to replace one on my Stude I'll have to go to reflectors and replaceable bulbs (H4 type) like I've had to with my other cars.
Actually, Halogen bulbs are incandesecnt too, but you know what I mean. :D
Kato
08-22-2017, 07:22 PM
I've been wondering about that very thing. I do see the GE halogen headlights that are on my GT available online and I would be wise to get a set before they are no longer available. As for incandescent sealed beams, also a thing of the past here to my knowledge. In fact incandescent bulbs for any use, home, auto etc.. have been all but banned! They call it progress!
bensherb
08-22-2017, 11:13 PM
As far as I'm concerned, change for the sake of change is not progress... it's "make" work keeping sombody's brother in law employed. Then again, I'm a crotchety old bastard, so what do I know! ;)
Kato
08-23-2017, 07:52 AM
Well then I am a crotchety old bastard too! ;) Cheers!
