Hey there Dudes and Dudettes! I'm looking to buy a Harmonic Balancer Puller for my '56 Golden Hawk. Anyone have one they're no longer using? --Kenny 425-351-2627
Harmonic Balancer Puller for 352
1950 Commander Land Cruiser
1951 Champion Business Coupe
1951 Commander Starlight
1952 Champion 2Dr. Sedan
1953 Champion Starlight
1953 Commander Starliner
1953 2R5
1956 Golden Hawk Jet Streak
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1962 Cruiser 4 speed
1963 Daytona Convertible
1964 Daytona R2 4 speed
1965 Cruiser
1970 AvantiTags: None
I just make do with a regular puller, and some creativity, but its a PITA. I agree, it would be great to have an original one. This should be interesting, in seeing if anyone out there has one for you. If anyone shows up with two, I call dibs on the second one.
Originally posted by Dwain G. View PostAmazon has a nice OTC set for under $100. Puller and installer kit. Packard uses a 3/4" 16tpi thread which comes in all the kits, unlike Studebakers odd size.
1953 2R5
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1965 Cruiser
1970 Avanti
Ken ...are you the guy who called me this morning about a CE in Hamilton ?sigpic
For what it may be worth -
The Studebaker engine does not have a "harmonic balancer". It doesn't need one. Very few engines need an external balancing weight attached to the damper.
It's a "harmonic damper". Or in other words, a shock absorber.
The part on the end of the crankshaft does no...act of "balancing" whatsoever. It's main purpose in life is to dampen crankshaft "harmonics", again, with no balancing of anything.
Originally posted by drrotor View PostHey there Dudes and Dudettes! I'm looking to buy a Harmonic Balancer Puller for my '56 Golden Hawk. Anyone have one they're no longer using? --Kenny 425-351-2627
We pulled another one the other day using a standard 3-jaw long arm puller. The special tool just isn't necessary.
jack vinesPackardV8
- Likes 1
Just use a little creativity with a large 2-leg or 3-leg puller, either will do. I have notched the inboard side of the puller arms, so the claws would get enough bite on the back side of the HB. Have also used a huge hose clamp to put around the puller legs so the claws would maintain their bite on the back side. The HB usually comes off fairly easy too, once you get it moving. Whatever you do, do NOT hammer on it.
I made a puller and successfully used it. Loaned it to Brent Hagen and he used it too. It pulls on the back of the center casting without pulling on the outer, rubber supported, ring. Works like a champ.1950 Commander Land Cruiser
1953 2R5
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1965 Cruiser
1970 Avanti
Originally posted by 2R5 View PostKen ...are you the guy who called me this morning about a CE in Hamilton ?
1953 2R5
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1965 Cruiser
1970 Avanti
Originally posted by drrotor View PostI made a puller and successfully used it. Loaned it to Brent Hagen and he used it too. It pulls on the back of the center casting without pulling on the outer, rubber supported, ring. Works like a champ.Restorations by Skip Towne
Why are we worried about pulling on the outer ring? Its pressed on from the back side and is fully captured and supported by the iron pulley. It can't be damaged or dislodged by the puller jaws using it as a purchase. We've pulled dozens that way.
jack vinesPackardV8
- Likes 1
