The new clutch on my '61 Champ began chattering and got progressively worse so I took it to my favorite repair shop in town which had done the clutch replacement. I went by there a few days later to check on progress and the owner said they had sent the clutch and pressure plate back to the outfit in Portland that did the clutch work in the first place. In the meantime they had discovered the truck had a pretty big hole in the exhaust pipe a few inches below the manifold which needed to be repaired. Fortunately their is a good independent muffler shop right next door and they could move the truck over to them when they got the clutch and transmission re-installed. All well and good.
I finally picked up the truck a couple of days ago and was pleased how much quieter the exhaust note was and the clutch worked even better than when I had the new clutch put in before. As I drove away, however, I noticed the speedometer was not working. I realized they had failed to reconnect it to the transmission. When I got home I looked under the truck and saw that the cable was hanging less than an inch from the ground. When I examined the end of it I saw that it had hit the ground and has a bit scuffed. As I looked at it I asked myself "How did they miss that? When the truck was on the rack getting the clutch work done it had to have been hanging right in their face. When they moved the truck to the muffler shop it must have still been hanging there yet the exhaust mechanic did not say anything to the mechanics next door, or just hook it up himself. It was way too obvious to miss.
I think I will have some fun with this when I take the truck back to have the cable reconnected.
