Working on the Flight-O-Matic in my 1957 Packard. Believe transmission is a type 8 Warner.
Had a selector shaft leak (big time) seals have been replaced. In order to access the shafts, I removed the pressure valve and control valve.
My question concerns the pressure valve.
The two pistons are very tight and hard to move. Are these pistons suppose to move freely? All fluid has been removed internally.
Thank you.
Thank you.
