Working on a '62 259 with an Auto Trans. It has sat a few years with no air cleaner. Owner said it did run... I assumed at the worst a compression check would show a rusty valve/ valve seat or something. It does run, but something is not right, it shakes and vibrates, so we tried the following:
Intake runners were not rusty, changed the intake manifold to be sure. inside the valve covers were clean.
Checked the fuel system/ new filters flushed the tank, checked the carb, even tried a spare. Checked for vaccum leaks, checked for proper voltage at coil. new points, Adjusted valves, ran compression checks- all were right near each other, checked for excessive crank endplay, checked the flex plate....
We did do spark plugs and wires. After one test run we did see 2 plugs were white/yellow more than the rest. The car runs ok, no signs of burning oil or water.
I have seen one run kind of like this, but it had a tapping noise due to a backed out pinch bolt. This feels more like something way out of balance like a miss fire, but we did do a lot of checking for that.
Any suggestions would be a good. Plans are to tear it down, and check it very carefully, for proper clearances, rod orientation etc but tips are always helpful.
