View Full Version : Transmission: Auto trans for '63 Lark
oberjim
07-27-2017, 12:35 AM
My wagonaire has three on the tree, which is getting loose and is a real hassle to wrestle with. After 15 miles or so, going into 3 rd gear from 2nd is grinding gears. I want to change it.
My question is: does anyone have experience in replacing my manual trans with o/d to a modern auto trans that will be an easy (relatively) swap out?
If so, what needs to be replaced? (Drive shaft, bell housing etc etc.) Does the x member chassis present any particular problem?
thanks mucho, in advance.
Jim
SScopelli
07-27-2017, 01:13 AM
Here is a write up on a 200r4 conversion in an Avanti. It also has the X-frame. Pro/Cons and cost.. Looks like the drive shaft was lengthen. Doing the swap with the engine in car with an X-Frame may require a few sentence enhancers, but do able.
http://www.studebaker-info.org/Tech/Bhend/Avantaodtransmissionswap4.pdf
bensherb
07-27-2017, 01:30 AM
I know it's pretty common to swap to a GM 200-4r or 700-r4 automatic overdrive. There are adapter plates available for the swap. I'm planning this swap in my GT. I'll be using the 700r4, I'll get it next month. I expect to have to change or modify the drive shaft and do some wireing for the converter lockup as well as a cable linkage for the throttle position valve in the trans. I don't anticipate any real problem with frame interferance or anything like that, but will probably need to make a rear trans mount. There was no problem when we put a turbo 350 auto in my dads '53 coupe.
There are also adapters available to use a modern OD 4 speed. It's likely with any non factory swap a drive shaft change/mod and a rear mount mod will need to be made.
Mrs K Corbin
07-27-2017, 07:44 AM
STOP! before you condemn the 3 speed, check to see if the rubber Bushings on the linkage are missing or deteriorated.
I once sold a 57/56 (Johnny Cash Style) Commander that had this exact issue. The day I sold it, I figured out what was wrong and fixed it before the buyer got there.
However I had already promised the car, so it was sold.
I miss that car.
41 Frank
07-27-2017, 08:42 AM
If the fixes mentioned here fail and you need a transmission.The most economical way to get your transmission operating properly is to purchase an exchange 3 speed transmission from SDC member Jerry Kurtz. He can also rebuild yours.
SScopelli
07-27-2017, 03:15 PM
Could be he would like the Auto transmission not only for the overdrive, but not having to shift..shift..shift..shift..shift..shift..shift..shift..shift.. on CA freeways and roads due to heavy traffic.
Last year I took one of my car that was stick, to a car event.
Started off in Point Mugu and Went through Mulholland Hills where it was a blast shifting, then ended up on the '1' off to our next rally point, Point Vincent Lighthouse, unfortunately that is Lincoln Blvd where I shifted more times than I care to count just to get through one light.
