View Full Version : Body: WHERE Does The Prop Rod Go!
345 DeSoto
07-20-2017, 07:52 PM
For the LIFE of me, I don't have the faintest idea where the prop rod goes on my Sky Hawk! Pictures would help greatly. HELP!...:confused:
ndynis
07-20-2017, 09:08 PM
Here is the way it works on my 61, attached to the Radiator support on one end and when folded down snaps into a clip on the other.
65781
studegary
07-20-2017, 09:58 PM
If you mean: Where does it go in the hood? There is a hole for the end of the rod in the tubular cross member near the front of the hood.
If you mean; Where does it go when not in use? See post no. 2.
sals54
07-21-2017, 12:05 AM
Did some of the Hawks prop on the left and some on the right? If so, would there be the possibility of having a left side rod support, and a right side hood? Just wondering.
Dwight FitzSimons
07-21-2017, 10:10 AM
Doesn't the hood prop rod "prop" on the right side of the car on LHC cars (i.e., US, Canada) and on the left side of the car on RHC cars (i.e., Australia, etc.)?
-Dwight
riversidevw
07-21-2017, 06:16 PM
I can't add much beyond post #2. But my car is at least a '56 (56J). I assume you have the mounting clip (believe it's #299777) for the prop? To attach the prop to the right radiator support?
As to LHC vs RHC cars, Dwight's theory is interesting. But I'm wondering what difference it would make for placement of the prop. Admittedly, I don't know the answer.
I seem to recall some running changes during the 56 model year, but mostly dealt with placement of the hole in the hood that receives the prop.
For whatever reason, the '55 K bodies have the prop on the other side.
brngarage
07-21-2017, 06:25 PM
The '53 K bodies also have the prop rod on the driver's (left here in America) side.
My very early (and Vernon) 56J has the hole for the rod (in the tubular brace on the hood) in a slightly different place (a little toward the center) than my friends later (South Bend) 56J. Very interesting......................
riversidevw
07-21-2017, 07:15 PM
Howard, my 56J is a very late Vernon car, built and shipped in June '56. It has the hole for the support rod in the outer location. Here's the strange part. The subject of placing the hole closer to the center line was first mentioned in the April '56 Service Bulletin. They say it was done to give more uniform support to the hood. They even suggest drilling a new hole on the earlier cars, that new hole about 8 inches from the center line of the hood. So you would expect to find it in the late production cars, not the very early ones.There's been no obvious sign of replacement of my hood, but guess we can't totally exclude some sort of panel replacements early in the life of either car. For mine, a conceivable explanation might be the LA plant using remaining parts from earlier in the year. Has anybody ever seen a Vernon-built 56J with painted interior window garnish moldings? My late car and several others use the early style polished stainless. Vernon plant must have been an "interesting" place in that final model year there.
Relevant 56J Service Bulletins are posted on Frank's 56J website.
Gil
sals54
07-21-2017, 10:34 PM
Those Hawk hoods always scare the carp out of me anyway. I can't even imagine what that would do a guys back should it come down by accident. Ugh.. I always use extra precaution when a Hawk hood it up. I use at least 2 other supports and leave the factory rod in its sleeping position. This also allows me to prop the hood in a higher position than stock so I don't scalp myself on the hood catch.
brngarage
07-21-2017, 11:51 PM
My error regarding the placement of the hole in the tubular support; I forgot that some previous owner replaced the hood with a '57 to '62 hood. OOPS!
By the way, I AM looking for a correct '56 hood if someone has one for sale.
bensherb
07-22-2017, 02:14 AM
You just need one of these. The hood will open a foot higher.
657976579565796
