View Full Version : Engine: Off topic(?) intake manifold question...
Noxnabaker
07-16-2017, 05:06 AM
Since I've got MoPar s.b. in my -55 sedan this might not fit here...?
1: Does anybody know about alu intakes for 318 engines?
(I want it as low as possible!)
2: & do I loose or gain torque with a low manifold compared to a higher one?
3: what might be the best/cheapest(low-priced, not badly made) brand?
Any thoughts?
Noxnabaker
07-16-2017, 05:07 AM
Oh yeah, there's also the question if anybody has one "laying around" for sale... ;)
doofus
07-16-2017, 06:59 AM
Which series 318 do you have, early or later. Doofus
Noxnabaker
07-16-2017, 05:17 PM
It's from -89, from a van we drove a lot.
tsenecal
07-16-2017, 07:11 PM
Check out all of the normal sites like Summit, Speedway, Jegs, Rock Auto. I would think that they would be fairly common.
DEEPNHOCK
07-16-2017, 07:15 PM
Remember that Nox is in Sweden...
Noxnabaker
07-17-2017, 04:39 AM
Yep, I'm in Sweden as Jeff points out. :)
& what year is the border for early or later Doofus?
doofus
07-17-2017, 07:03 AM
Nox you have the late or LA series engine,273,318,340 360. there was an odd factory 180 deg 2 bbl manifold around '78 that was really low. it was on trucks. after market is probably your best bet. seems like '64 was the early/ late break point but not set in stone. avoid "Hi Rise" style, stick with factory style if possible. Luck Doofus
shifter4
07-17-2017, 07:11 AM
Here is some reading :
https://en.wikipedia.org/wiki/Chrysler_LA_engine
http://www.allpar.com/mopar/318.html
https://www.novak-adapt.com/knowledge/engines/about/dodge/mopar-small-block/
Noxnabaker
07-17-2017, 02:04 PM
When I just got the donor car (-77 Volare wagon) I read all that, got me confused & for a while thinking that maby it was a 360 since it said the 318 only came with 2-barrel that year & my Dutch sold had 4-barrel.
But then there was more changes, I was used to Swedish sold cars who had 15 inch wheels & happy about that & the donor car had 14 inches, not so happy about that...
Anyway, Jeff is helping me to get a good manifold now!
lynnbogart
07-21-2017, 06:08 PM
If You can find one, the 2 barrel manifold from the 1964-1967 273 was "state of the art" at the time, may be a version of the one doofus alluded to, trucks had some different parts than cars at times.
I put one on a 73 318 pickup and got better performance and economy. Just saying. Particulars are that the intake manifold was a hybrid single/dual plane design that used one plenum for each side of the engine, joined by a carefully sized rectangular passage that solved lean/rich problems that had occurred with the original “purely” dual plenum design that had dedicated one barrel of the Carter BBD two-barrel carburetor to each bank. This reduced the height of the engine and allowed installation in the Valiant. Same thing would apply to Stude hood.
Noxnabaker
08-02-2017, 03:50 PM
Things takes time & stuff gets in the way... but I discovered the timing chain was waisted, no miss firing but really slack & here's the thing: When I did my original -77 318 some years ago it had a chain tensioner but the -89 don't & when googeling I found out that only magnum V8 & V6 has it original.
That got me wondering if Studebaker V8 has/had it?
(This is mine this evening:)
Just wondering...66025
Treblig
08-02-2017, 04:17 PM
You'll find a ton of information at this Mopar forum:
http://www.forabodiesonly.com/mopar/
There are many, many members (from all over the world) who can give you all the engine info you need and there also many parts for sale. All you need to do is find a Mopar enthusiast close to you that has the parts you need.
treblig
08-02-2017, 04:40 PM
/Cut/That got me wondering if Studebaker V8 has/had it? Just wondering.../Cut/
No, a Studebaker would not need a Tensioner, since there ARE NO Timing Chains or Sprockets! :rolleyes:
Noxnabaker
08-02-2017, 04:43 PM
Yes, Treblig I know, been there - done that, & more... ;)
I was just wondering about what StudeRich answered.
Alan
08-02-2017, 06:00 PM
Gear drive, direct, gear to gear.
