View Full Version : Engine: Oil & Lubricants for Classic Cars
Ron McGuire
07-13-2017, 08:58 PM
This post is strictly to help those preserve their automobiles. Please note there is no monetary gain for myself.
In my short time experience with the Studebaker Forum I have observed several questions posted about the availability of oil for Classic or Antique cars. Especially SAE 30wt engine oil with zinc. This company has been my go-to for the past 25 years. Their 30wt oil only came in 5 gallon pails, I recently discovered that it comes in quart sizes which, of course, is definitely more user friendly. Here is a contact for a dealer of SCHAEFFER'S OIL MFG. in SW Missouri:
Harald's Small Engine Inc.
Richard & Debbie Harald, 417 743 2491, fax 417 743 2314,
5214 Jasmine Rd. Billings Mo 65610.
To contact Schaeffer's directly call 1 800 325 9962
Schaeffer Specialized Lubricant Company,
102 Barton Street, St. Louis Missouri 63104
www.schaefferoil.com.
Happy Motoring!
Studebakercenteroforegon
07-14-2017, 03:06 PM
I will say that Schaeffer Oil is one of the most comprehensive lines of oil and lubricants, well known in many markets except retail to the average car owner.
I knew about them because many teams that race asphalt oval super late models use Schaeffer Racing Oils.
I do have a local distributor which is handy.
Ron McGuire
07-15-2017, 05:19 PM
Do you run Schaeffer's Oil products in your Studebaker's? Were you aware of the 30wt that now comes in quarts?
07-15-2017, 08:43 PM
Ron, revisions or deletions of your posts here can be done using the "Edit Post" function.
Ron McGuire
07-16-2017, 11:15 PM
Ok, some of us aren't as 'Tech Savvy' as others.
07-17-2017, 12:08 AM
Yes, I use Schaeffers Oil in my Studebakers. I prefer the 9000 series full synthetic. I use 5W-40 and I like to buy the gallon size.
Used in 259 V-8 engines.
bsrosell
07-17-2017, 10:38 AM
I know, I'm sure there are reams of posts on this topic via search engine, but one simple question as I've never heard of this company before, and appears very specialized; what would be the practical difference between using 9000 series synthetic (I only use synthetic oils for all my cars now), and using Mobil-1 synthetic and adding the appropriate amount of ZDDP with each oil change? (that said, I may do a search and see who distributes the Schaeffer's oil in Mpls/St.Paul. If local, no worse than driving to WalMart for Mobil-1 ;-)
thanks!
Barry
bsrosell
07-17-2017, 12:23 PM
Well; I see there is a Schaeffer rep 6 miles away from me in Woodbury, MN. :-)
Joshua Skinner
07-18-2017, 01:35 AM
If you want Mobil 1 with more ZDDP the 15W-50 has more. I don't think it's necessary to dose modern API oils with extra ZDDP. I just run a heavy duty engine oil. 10W-30 for most things and 15W-40 in tired things.
Ron McGuire
07-18-2017, 01:56 AM
I prefer to use Schaeffer's Lubricants for many reasons. Just to name a few: (oops, I did get pretty lengthy after all)
They are all American from ground to bottle. Everything done in the good ole U S of A
They use the very best base stocks and additives.
Two things that I know no one else has: Micron Moly and Penetro.
Certain oils of Schaeffer's have extra zinc which is absolutely necessary for older engines.
Spending some time with a Schaeffer rep will prove to be time well spent. They should have a list of common oils and where they rank. Yes, Mobil will be on the list but you may be surprised where they rank. Schaeffer's does not do regular advertising just simple word of mouth or heavy industry.
Plus they've been in business since 1839. Please let me know what you think. Best regards, Ron McGuire
07-18-2017, 06:56 PM
Probably the Studebaker Conestoga Wagons heading west on the Oregon Trail used Schaeffer's "Black Beauty" axle grease!
Ron McGuire
07-18-2017, 09:49 PM
Do your Studebaker's seem to perform well on the 5W-40?
Ron McGuire
07-18-2017, 09:53 PM
Studebaker only used the best.
07-18-2017, 10:16 PM
Yes, in that there is no oil consumption, no smoke, and reasonable oil pressure in a 90,000 original mile partial flow 259" V-8.
1961 Lark hard top.
Ron McGuire
07-21-2017, 12:17 AM
That's awesome! I wouldn't have thought that 5w-40 would have been thick enough. Good to know.
Joshua Skinner
07-21-2017, 02:19 AM
5W-40 is really only thinner than SAE 30 when cold. Which is a good thing! You could even go 0W-40 and as many of those oils meet the BMW LL-01 spec they are very high performing, as are the LL-01 5W-40 oils.
I had some Mobil 1 0W-40 left over from previous BMW ownership and I used it in my '15 Nissan Frontier 4-banger, but I felt it was a little thick so on the next oil change I mixed it 50/50 with Mobile 1 5W-20.
There are tons of test results at the PQIA web site if you want to know what's in many oils. https://pqiablog.com/ (http://pqiamerica.com/)
You can see viscosity, additive levels, NOACK volatility, etc. Like this test of Valvoline Premium Blue 15W-40. http://pqiadata.org/Valvoline_Blue_15W40_4192017.html
Or this side-by-side test of 7 15W-40 samples. http://www.pqiadata.org/SAE15W40SamplesTest2016.html
