View Full Version : Empty Weight of a 1953 Commander Hardtop
53 Commander
07-09-2017, 07:41 PM
I know this has probably been it on before, but does anyone know what the empty weight is for a stock 1953 Commander Hardtop? It has A/T, P/S & Radio.
studegary
07-09-2017, 08:49 PM
3120 pounds - of course, any options (automatic, radio, etc.) add to that.
Alan
07-09-2017, 09:39 PM
I don't go much by shipping weights published by Stude. My 53K weighs in on the scales at 3,445 lbs. with 5 gallons of gas in the tank. I couldn't get it down to 3,120 lbs. with a SBC and trying to get it a light as possible.
studegary
07-09-2017, 10:10 PM
Don't forget that you have to add the extra weight of automatic transmission, power steering, radio, five gallons of gasoline, etc. (perhaps even A/C) to that 3120.
S2Deluxe
07-09-2017, 11:54 PM
The factory shipping weights published in the '51 - '54 Studebaker shop manual are dry shipping weights, assuming no options. A standard 3 speed manual transmission. No automatic transmission, no overdrive, no power steering, no power brakes. While the manual does provide additional weight figures for these options, they are also dry shipping weights. They do not include the weight of the gas in the tank, the coolant in the cooling system, the oil in the crankcase, the oil in a standard transmission and in an overdrive if so equipped, automatic transmission fluid in the automatic transmission and torque converter if so equipped, power steering fluid in the power steering system if so equipped and finally differential lubricant. I'm not sure exactly how much the weight of all the specific fluids in any particular application might be but it's not insignificant!
Mark
warrlaw1
07-10-2017, 03:31 PM
I have to weigh in the 55 at the Pure Stock Drags. 3400 sounds reasonable with automatic, dual exhaust, spare tire, etc.
studegary
07-10-2017, 04:04 PM
And that is with all of that extra die cast (pot metal) chrome on a 1955 <G>.
