View Full Version : Engine: Dropping the Oil Pan in a 1946 M15
jz5rcc
07-08-2017, 05:12 PM
Dropping the oil pan should not be this difficult. I had to remove the starter and cable to get at the bolts but how do I get the pan out without taking apart the steering linkage. It is close but just will not go. Am I missing something here?
Treblig
07-08-2017, 05:23 PM
Did you try rotating the crank to get more clearance or disconnecting and motor mount to raise the engine a 1/2"??
treblig
jz5rcc
07-08-2017, 06:47 PM
nope will try tomorrow. Thanks for the suggestions. The 1/2 inch should be all I need
tsenecal
07-08-2017, 11:36 PM
Jacking the frame up, and letting the suspension drop down, might give you a little bit room. Good luck!
doofus
07-09-2017, 07:09 AM
Try a bottle jack between the spring and frame and push axle down a bit, one small one per side. Luck Doofus
