View Full Version : Engine: Oiling system plug
3x2stude
07-05-2017, 10:42 PM
65400Is there any theory on why Stude used the odd slotted plug for the machining path for the distributor gear oiling hole? It is always a bitch to get out.
JK
thunderations
07-06-2017, 10:22 AM
It probably cost 3 cents while an allen head one was a nickel.
sweetolbob
07-06-2017, 01:20 PM
JK
If it's a pain to get out, MIG weld a nut on it that will slip over it and replace it with a more normal configuration. Bob
altair
07-08-2017, 09:41 PM
It is imperative that you have a square good tight fitting screwdriver, one that is rounded will only cause more trouble. Lots of pressure with a square shaft and crescent wrench and steady but deliberate turning. I just removed mine on a 259 with no issues.
doofus
07-09-2017, 07:12 AM
I have used an impact driver with proper fitting bit more than once. Luck Doofus
