Need help to identify a Studebaker
There is no difference between the cabs used on M5 and M15 trucks. The M16 and M17 trucks had a cowl section that was indented to accommodated the larger Commander 6 engine, but the cabs were otherwise identical to those used on the smaller trucks. The later M-series trucks used a much larger front bumper, and that did alter the appearance of the truck, but the same cabs were used. The data you provided are from the cab serial number, not the vehicle serial number. There is no real significance to that number -- it was used to track running changes to the cab, but was not sequenced with the vehicle serial number.
More info in chapter 7 here:
Skip Lackie
Your truck appears to be an M15 on to which someone has transplanted the cab (and its serial number plate) from a 1948 M5. As noted above, the cabs are the same anyway. Whomever did that should have moved the serial plate from the M15 over to the new cab. What does the title say?Skip Lackie
I'm pretty sure, (have not checked for years), my Studebaker truck, is registered by its engine number. I suppose, that if I ever get around to putting the V8 in it, I'll have to investigate changing the number on the (South Carolina) title to the truck's serial number.John Clary
