I'm getting 40 lbs of oil pressure at idle on my freshly rebuilt 289. Is that good, bad, typical?...
40 lbs At Idle
Depends on weight of oil, outside temp, engine temp, and whether just slowing down after 50+ miles of hammering down the highway, or puttering around town. Mine generally idle at 30-40 PSI, and run down the road at 45-50 PSI. I use Mobil 1, 15W50 oil, year round, with 195 degree stat to keep motor temps around 190 degrees. After a fresh rebuild, a 259/289 will often run a little higher for the first 5000-10,000 miles.
Joe Hall's response is similar to what I would have posted, including recognizing that you mean PSI when you state "lbs".Gary L.
